Activity Forums Adobe After Effects Add repeater to layer, does not rotate correctly
  • Add repeater to layer, does not rotate correctly
    Posted by Steve Davies on March 12, 2019 at 12:03 pm
    I am trying to make a ‘flower’ shape, and using Add Repeater to the layer, but despite the position being set to 0,0 – the position is off when I add a rotation.
    Do you know what I am doing wrong? I have tried to place the repeater in different places in my Group / Contents.
    thanks!
    Steve
    Steve Davies replied 7 years, 4 months ago 3 Members · 4 Replies
  • Steve Bentley
    March 12, 2019 at 4:58 pm
    Inside the transform of repeater 1 (not the transform for the group or shapes, I know – couldn’t find another name for it?) is an offset which defaults to 100. Change that to 0.
  • Steve Bentley
    March 12, 2019 at 4:59 pm
    Sorry, didn’t finish the thought. The repeater’s transform is also where you put the rotation, and not in the “outer” transform.
  • Max Haller
    March 12, 2019 at 9:44 pm
    you’ll probably need to adjust the anchor point in the repeater 1 transform. that’s the pivot point which the copies will rotate around. Also adjust the position like Steve recommended.
  • Steve Davies
    April 30, 2019 at 12:27 pm
    Thanks Max!
    Digital Designer
    stevedavies.io
