Activity › Forums › Adobe Photoshop › Add Rainbow Anodizing to Metal
  • Jonathan Ziegler
    January 5, 2013 at 6:35 pm
    Easiest way is to create a “map” of the rainbow coloring you want to add and put that in a new layer on top, mask out the areas you don’t want to have rainbow, likely set the blend to “color” and then vary the opacity.
    You can make a bubbly rainbow pattern with a huge variety of tools – render clouds, add a rainbow gradient map, use ripple, glass or some other distortion, or swirl or what have you, etc.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
