Activity Forums Adobe After Effects Expressions Add Prefix & Suffix to an array in sourceText
  • Add Prefix & Suffix to an array in sourceText
    Posted by Roland R. kahlenberg on November 25, 2013 at 9:07 pm
    I’ve got a comp where a user enters the following data into a Text Layer – up to 20 different values are allowed.
    The following is an example of how the text is formatted:
    [ 211 , 251 , 230 , 231 , 155 , 140 , 70 , 214 , 190 , 262 , 210 ]
    In another comp, using a single Text Layer with multiple Range Selectors, I have been able to parse each number and place each number in different places in the comp.
    I would now like the user to be able to add a Prefix and Suffix. These can be typed in another Comp, in another Text Layer. I would like these to be automatically positioned at the front and back of each number.
    Is this possible with a single Text Layer? And if it’s possible,
    what’s the Expressions to achieve this?
    TIA
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
    Marcel Tineo replied 12 years ago 3 Members · 2 Replies
  • David Alex
    December 2, 2013 at 3:36 pm
    Hmm, I’m not sure how to solve this particular problem, but when I work with SourceText I find you can add strings.
    Example, I can use a Slider to control a number representing a %, and I need that symbol at the end and the digits within square brackets. I can do it like this:
    "["+Math.floor(effect("Slider Control")("Slider"))+"]%"
    This method doesn’t always work, as I found without the “Math.floor” rounding off the slider the expression doesn’t work, but hopefully it should help with your case, as you can replace the slider reference with a reference to another text layer.
    Hope it helped 🙂
    Ideas to Creations | Motion Graphics, Visual Effects and Digital Art inspiration, tutorials and much more!
    https://ideastocreations.blogspot.com
  • Marcel Tineo
    September 21, 2014 at 4:29 pm
    Yeah!! that worked for me, I only had to delete the… [] and that was it. Thanks!
