Activity Forums Maxon Cinema 4D Add points/detail to polygon
  • Add points/detail to polygon
    Posted by Scott Smith on February 5, 2014 at 1:10 pm
    I have a model of a football stadium, I want to use it in after effects as a the OBJ for Trapcode Form, however there isn’t much definition in the model to make the Form version look like the Stadium, can I somehow increase the number of points on all edges of the polygon model? Basically an opposite of optimization.
    thanks in advance
    Scott
    Adam Trachtenberg replied 12 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    February 5, 2014 at 4:14 pm
    Use Mesh>Commands>Subdivide. If you click the little icon to the right of the command name it will pull up a dialogue where you can increase the subdivision levels.
