Activity › Forums › Maxon Cinema 4D › Add point
Add point
Posted by Elie001 on October 14, 2007 at 2:36 pmi’m creating a new project i’m using points ,when i use the add point nothing happens and i can’t see the points when i use the polygon
i’m new with cinema 4d
please any help
Nolan Scott replied 18 years, 11 months ago 2 Members · 3 Replies -
Nolan Scott
October 14, 2007 at 7:51 pmTry this:
Create a Cube and make it Editable (C) /
select the Use Points Tool /
go to Structure / Add Point /
in the Viewport hover your cursor over any edge or line
(the line will go white) click anywhere on this line to set a new point /
switch to the Move Tool (E) and move any point into position.Cheers
Nolan -
Elie001
October 15, 2007 at 8:15 pmthe problem is that i’m unable to seethe points of the cube in point mode maybe i have a problem in point color (if so where i can change the color)
Thx
Nolan Scott
October 15, 2007 at 11:39 pmIn Point mode, when you come close with your cursor to any point,
they turn a little bigger and white, to make it easier to select.
(I presume you made the cube editable ? = Functions / Make Editable)To change the colour of your points, go to Preferences / Viewport / Colours /
Active Points or Inactive Points.Another idea might be, to see what you
