Activity › Forums › Apple Final Cut Pro Legacy › add overlay to multiply clips
Posted by Anton Lundh on March 29, 2010 at 2:48 pmHi all!
I really need to know if there’s a way to add overlay to multiply clips at the same time.Thanks^^
Todd Gillespie replied 16 years, 5 months ago 2 Members · 3 Replies -
Todd Gillespie
March 29, 2010 at 6:11 pmHi,
You’re question is a little vague…but if I understand you can apple click multiple clips from your browser, then either drag them onto your sequence as a overlay, F9 them onto the sequence, or drag to the canvas window for the overlay command.
Plenty of choices.Good Luck,
Todd at UCSB
Television Production -
Anton Lundh
March 29, 2010 at 7:44 pmThat’s not what I meant:(
I’ll try to explain a little better:D
If you right click on a clip in your sequence you can chose composite mode and then chose overlay. I need to do this on multiply clip at the same time.
Hope this was clearer^^
Todd Gillespie
March 29, 2010 at 9:12 pmAh, much better.
Click and drag over the clips you want to effect or apple click on individual clips and then right click and choose overlay.
Good Luck,
Todd at UCSB
