Activity › Forums › Adobe Premiere Pro › Add multiple transitions at once
  • Add multiple transitions at once
    Posted by Andy Brennan on June 24, 2008 at 9:29 pm
    Hey all! I’m sure I knew how to do this once, but how do I select multiple clips in my timeline and apply a default transistion to every spot where a transition would go?
    I use dissolves constantly, and I just want to “Select All” and apply a dissolve to large portions of my video. Anyone know how?
    Jon Barrie replied 18 years, 2 months ago 2 Members · 3 Replies
  • Jon Barrie
    June 25, 2008 at 1:10 am
    Sorry Mate, this is not do-able in CS3 I usually have fingers over shortcut keys, Ctrl+D and move the playhead near the cut points with the mouse and keep slamming the shortcut.
    However CS4 looks like it will have this function along with many others we’ve been crying about for many years. I’m praying that cs4 gets many workflow stuff right and no bugs!
    – Jon 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Andy Brennan
    June 25, 2008 at 6:29 pm
    When I try hitting CTRL+D with the playhead at a transistion, nothing happens…what’s this trick shortcut that I’m not doing right?
  • Jon Barrie
    June 26, 2008 at 1:31 am
    If you are already on a transition it needs to be deleted. This shortcut will only work on cuts, not transitions already there.
    – Jon 😉
