Activity Forums Boris FX Add moving hand to write-on text
  • Add moving hand to write-on text
    Posted by Simon Hagan on April 16, 2011 at 10:31 am
    Hi. I’m using Boris in Avid – Avid FX 5.8.2.
    I have some writing that I’ve used the paint tool to create a write-on effect – no problem there. And I have an overlay photo of a hand holding a pen. How do I get the hand to track along the path I’ve already created in the paint tool, so that the hand appears to be drawing?
    Simon
    Simon Hagan replied 15 years, 4 months ago 2 Members · 2 Replies
  • Peter Mcauley
    April 19, 2011 at 7:40 pm
    Hi Simon,
    You can do that by using the motion tracker to capture the motion of the paint as it paints on screen and then taking the motion tracker filter with the recovered motion and applying that to the hand image track.
    You can find free motion tracking tutorials here:
    https://www.borisfx.com/tutorials/RED.php
    I hope this helps!
    Cheers,
    Peter.
  • Simon Hagan
    April 19, 2011 at 8:20 pm
    Thanks Peter. I’ll give that a try.
    However, I was wondering if there might be a way to simply convert the paint path I’ve created into a motion path then apply that to the hand layer. It seems a short jump conceptually, but maybe there’s some reason that it can’t be done? I’ve tried to copy (ctrl+c) the path, as well as “convert filter” While convert filter seems to turn the paint path into a motion path, I can’t find a way to attach the hand layer to the newly created motion path. It doesn’t seem to work according to the normal rules of applying a motion path.
    Simon
