Activity Forums Adobe Premiere Pro add markers with intervals
  • add markers with intervals
    Posted by Nader Subaih on July 27, 2012 at 9:26 am
    Hi, I am trying to add markers every two seconds on the timeline since i have a beat that repeats every two seconds and i am trying to sync video to it. is there an easy way to add markers with exact intervals rather than doing it manually?
    thanks in advance.
    I am using Pr CS6
    Nader
    Joery Duco replied 5 years, 10 months ago 3 Members · 5 Replies
  • Angelo Lorenzo
    July 28, 2012 at 6:00 am
    Not really. Premiere isn’t scriptable. I would suggest going to Edit > Keyboard shortcuts and assign a keystroke to the marker function so you can watch and tap the marker key to the beat.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Nader Subaih
    July 28, 2012 at 9:28 am
    thanks Angelo, the key set marker is mapped to M key, and that is what i have been using, but my reaction time is not as precise as i would like. to me, it is much simpler than scripting, i want to essentially tell Pr to put marker every 2 seconds, which should be a breeze if the feature existed. there is something called extended marker, but that is no help either. are there any plug-ins that makes working with music easier?
  • Angelo Lorenzo
    July 28, 2012 at 9:47 am
    If you have After Effects, you can use clip/timeline markers and I would imagine a Google search would reveal some scripts to automate it. After Effects also has some expression control for audio amplitude.
    In After Effects, you can go to File > Export > Premiere project. The markers do come over to Premiere.
    In Premiere, there are no plugins that do what you need to do. After speaking with a plugin developer about a different use for timeline markers, Adobe doesn’t allow plugins to add markers to clips or timelines.
    Angelo Lorenzo
  • Nader Subaih
    July 28, 2012 at 11:18 am
    Great tip. I guess I need to learn me some AE.
    thanks again.
    Nader
  • Joery Duco
    October 20, 2020 at 4:36 am
    Here’s a quick tip. Put your first marker on the first two seconds of your timeline. Then cut a video clip and fit to it. Copy and paste the video clip (each clip is 2 seconds long) up to how many seconds you want. Then go back at the beginning of your timeline. You alternately press Arrow Down on your keyboard then M for the marker. This will mark your timeline every two seconds. 🙂 You’re welcome. God bless.
