Activity Forums Adobe After Effects Expressions Add marker everytime a value is detected
  • Add marker everytime a value is detected
    Posted by Rodrigo Aben on April 27, 2020 at 2:18 am
    I wrote the code below to detect whether opacity value meets a certain threshold and add a marker, except it stops at the first time it finds the value.
    I want it to continue finding matches and add multiple markers until it reaches frame 100.
    What am I missing?
    var comp = app.project.activeItem;
    var videoLayer = comp.selectedLayers[0];
    var time = comp.time;
    var frame = Math.round(time/comp.frameDuration);
    var opacityLevel = videoLayer.property("Transform").property("Opacity");
    var threshold = 48.0;
    above = false;
    while (true){
    t = frame * comp.frameDuration;
    if (above){
    if (opacityLevel.valueAtTime(t,true) != threshold){
    frame++;
    }else if (opacityLevel.valueAtTime(t,true) == threshold){
    above = true;
    var myMarker = new MarkerValue("Cut");
    videoLayer.property("Marker").setValueAtTime(t, myMarker);
    if (frame == 100){
    break;
    frame++;
    Rodrigo Aben replied 6 years, 4 months ago 2 Members · 2 Replies
  • Andrei Popa
    April 27, 2020 at 7:00 am
    First of all, never do a while loop with a condition that is always true. You should put your break condition there.
    And your above variable does not let the script check again for threshold equality. You must have a situation when that gets back to false.
    Haven’t tested, but give this a try:
    var frame = Math.round(time / comp.frameDuration);
    above = false;
    while (frame <= 100) {
    if (above) {
    if (opacityLevel.valueAtTime(t, true) != threshold) {
    frame++;
    above = false;
    } else if (opacityLevel.valueAtTime(t, true) == threshold) {
    above = true;
    frame++;
    Andrei
    My Envato portfolio.
  • Rodrigo Aben
    April 27, 2020 at 5:59 pm
    Works like a charm! Thanks Andrei!
