Activity Forums Adobe After Effects Add light to text with the ramp effect applied
  • Add light to text with the ramp effect applied
    Posted by Mike Tomei on March 16, 2010 at 5:13 pm
    Hello everyone,
    I’m pretty new to After Effects, so I’m hoping someone can explain this to me. I have a text layer with the “ramp” effect added to give it a gradient. I made the text layer a 3D layer, added a new light layer, but the light won’t affect the text layer. If I turn off the ramp effect, then the light will affect the text layer.
    I’m having a hard time understanding why this would be. Thanks.
    Mike
    Darby Edelen replied 16 years, 6 months ago 3 Members · 2 Replies
  • Bruce Wainer
    March 17, 2010 at 1:32 am
    i believe effects are applied after lights. Try precomping the text layer (with ‘move attributes into precomp’ selected), as AE will now treat the text as an image with an alpha channel, rather than text with effects applied. To change the text, just go into the precomp.
  • Darby Edelen
    March 17, 2010 at 2:59 am
    [Bruce Wainer] “i believe effects are applied after lights.”
    Effects are not normally applied after lights, however a text layer is a special case.
    Text layers are continuously rasterized. As a result the effect will override the light. If you pre-compose the text layer the light will work. In that case you can apply the Ramp effect on the text layer inside the pre-comp or on the comp itself in the main composition. It will work either way.
    Darby Edelen
