Activity › Forums › Apple Final Cut Pro › Add Keywords to Clips Already in Timeline?
Posted by Jeff Krieger on October 27, 2014 at 6:10 pmHi Everyone,
Out of curiosity, is it possible to add keywords to clips I’ve already put in the timeline? I tried dragging them back up to the keyword folder I want them all to have, but that doesn’t work. 🙂
Thx!
JeffBret Williams replied 11 years, 6 months ago 5 Members · 6 Replies -
Robin S. kurz
October 27, 2014 at 6:20 pmNo. You could at best match frame (⇧F) a clip and assign one, but that’s not recursive AFAIK.
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Bret Williams
October 27, 2014 at 6:56 pmThat’s the only way I know of. But once you keyword it its key worded everywhere. It really is silly you can’t keyword grime the timeline. Especially when a client hands you a premiere project that was organized by sequences instead of bins. I can convert the project to X, but there’s no way to drag the clips from timeline to anywhere.
Craig Alan
November 1, 2014 at 7:57 pmHow is a keyword helpful once a clip is in a sequence?
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
Bret Williams
November 1, 2014 at 8:12 pmWell in this instance the client created a bunch of sequences serving the purpose of key wording/selects in premiere. I XML’d it over to X. Now in X I’d rather not edit by copying and pasting between sequences. If I could open a sequence in a source monitor it wouldn’t be as terrible, but in X the concept of editing between sequences is even more tiresome.
So…. I’d like to simply drag all the clips in the sequences to their appropriate keyword collections so I can edit normally. Other NLEs would allow you to drag clips in a sequence to a bin no problem.
To do so in X requires match framing every clip then keywording one by one.
Marlon Bos
March 16, 2015 at 4:24 pmMy workaround:
– make a Smart Collection, with the parameter Used Media on
– open the timeline/project with the clips you want to Keyword
– all the used clips in that project will now show up in your Event Viewer (with the Smart Collection selected)
– select all the clips, then do an ‘alt-X’ to reset all the in- and out-point
– do a select-all again, and keyword them all at onceDone 🙂
