Activity Forums Adobe After Effects Add keyframe shortcut
  • Add keyframe shortcut
    Posted by Bill Clotz on July 31, 2005 at 11:41 pm
    What is the shortcut to add a keyframe? In the keyframe list it just says “Alt + Shift + property display shortcut” but I don’t understand what this means.
    Tim Kocher replied 17 years ago 3 Members · 3 Replies
  • Steve Roberts
    July 31, 2005 at 11:44 pm
    You need to specify which property gets the new keyframe. Those shortcuts are also in the list.
    e.g. position is “P”, so to add a position key, you choose alt+shift+P.
    Steve
  • Bill Clotz
    August 1, 2005 at 1:02 am
    Ah, ok, that makes sense now.
  • Tim Kocher
    August 12, 2009 at 7:58 am
    But what if it is for an Effect’s property. I tried SHFT+ALT+E, but that just opens the Edit Menu. Any idea, or is it not possible?
