Activity Forums Adobe After Effects Add Keyframe??
  • Add Keyframe??
    Posted by Henri Yates on August 7, 2021 at 10:13 am
    Hi everyone!
    I am trying to set a shortcut for the “Add Keyframe” in After Effects CC 2014.
    through the shortcut txt file in AppData\Roaming\Adobe\After Effects\13.0 but I can’t seem to find it there or I am missing something.
    Any help? Script or something?
    I have cc 2014 and cc 2019 but I use cc 2014 because it loads up faster than cc 2019.
    Henri Yates replied 4 years, 10 months ago 3 Members · 4 Replies
  • Chris Voelz
    August 7, 2021 at 1:53 pm
    There is a shortcut for the standard transform properties.
    Alt + (p,t,s,a,r)
    Outside of that I found this. https://adobe-video.uservoice.com/forums/911311-after-effects/suggestions/34046050-a-keyboard-shortcut-to-add-a-keyframe-to-which-eve
    I think 2019 has the visual shortcut editor, that might be able to help narrow down where to change it in 2014?
  • Henri Yates
    August 7, 2021 at 2:11 pm
    I know about the Alt + (P, T, S, A, R) but what if you have a property like say trim path, start/end, offset etc?
    Thanks for replying though.
  • Meng Zhiqun
    October 30, 2021 at 3:28 pm
    There are no hotkeys for that. However, I’ve done a script to set a key at the current time to any selected properties. You can set a shortcut key to this script. So in a way, this shortcut key adds keyframe to any properties that you want. You can save this as a .jsx and place it in the ae, scripts folder.
    var proj = app.project; var projComp = app.project.activeItem;
    var selProp = projComp.selectedProperties;
    app.beginUndoGroup("Add Key");
    for(var i = 0; i < selProp.length; i++){
    var curProp = selProp[i];
    curProp.addKey(projComp.time);
    app.endUndoGroup();
    Hope this helps!
  • Henri Yates
    October 31, 2021 at 10:46 am
    Thank you.
