Activity Forums Apple Motion Add key frame without going to timeline?
  • Add key frame without going to timeline?
    Posted by Scot Walker on April 7, 2005 at 6:33 pm
    I’m using the Record button to create some basic key frames for things like filters (gaussian blur, what else?) and I can’t figure out how to add a key frame without going into the key frame editor.
    I press the Record button.
    I click on my photo and press the record button.
    I move the playback head to about 10 frames into the image.
    I adjust the gaussian blur to 0.
    I need it to be 40 at the first frame.
    Then 10 frames before the end of the photo, I need a key frame of 0 again.
    Then put the blur at 40 at the end.
    This requires 4 key frames.
    The Record button only gives me a key frame if I change something.
    Greg Niles replied 21 years, 5 months ago 3 Members · 3 Replies
  • Scott Sailor
    April 7, 2005 at 8:12 pm
    This may or may not help, but when you are at the beginning of your timeline and press the record button, click on your object and wiggle it’s position. What I mean by wiggle is move it, then move it right back to where it was. Motion should create a keyframe even though nothing was changed.
  • Scot Walker
    April 7, 2005 at 11:24 pm
    That’s not optimal, but it will work.
  • Greg Niles
    April 8, 2005 at 12:05 am
    Use the animation menu to the right of each parameter in the inspector, there’s an Add Keyframe option there.
    — Greg
