Activity Forums Maxon Cinema 4D Add geometry to hair
  • Add geometry to hair
    Posted by Afonso Tres on August 29, 2011 at 10:58 am
    Hello guys,
    Im trying to make an eagle and i want to model a simple feather (a single plane shaped like a feather).
    My question: is it possible to apply geometry to the hair guides??
    Im talking about a custom shape, an object that i model, not polygon hair
    is it possible??
    thank you.
    Adam Trachtenberg replied 15 years ago 2 Members · 3 Replies
  • Adam Trachtenberg
    August 29, 2011 at 2:35 pm
    It is possible. You have to go to the hair object’s generate tab and set the type to instance. Then drag your feather into the object box and adjust the settings to taste.
  • Afonso Tres
    August 29, 2011 at 4:26 pm
    Thank you Adam! that’s it!
    But now i have another question. And if i want to bake the hair geometry to a point cache tag?
    i know i can cache the animation in the cache tab of the hair object but that is not what i want
    i want to bake it to a point cache tag to have the ability to control the strenght and the duration of the animation (to speed and to slow down)
    or maybe if i want to export the resulting mesh to another 3d software…
    thank you
  • Adam Trachtenberg
    August 30, 2011 at 3:38 am
    I don’t know of any way to bake Hair to PLA.
