Activity › Forums › Adobe After Effects › “Add” generates a black border – 32-bit linear
  • Simon Ubsdell
    January 14, 2018 at 5:00 pm
    If you add a negative value to a positive value you will get a subtraction.
    The chances are that the element you are trying to add has negative values (in the deep blacks at the edges), i.e, pixels that are below zero.
    Hence the darkening effect.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Walter Soyka
    January 15, 2018 at 9:54 am
    [Simon Ubsdell] “If you add a negative value to a positive value you will get a subtraction.”
    Indeed, this is one of the ways that 32bpc floating point works differently than 8bpc/16bpc.
    The Levels effect has an option to clamp black and/or white. Add Levels, leave the “normal” Levels controls (the histogram, inputs, gamma and outputs) alone, and change “Clip to output black” from its default “Off for 32bpc color” to “On.”
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
