Activity › Forums › Apple Final Cut Pro › Add Extra text layer to Title?
  • Add Extra text layer to Title?
    Posted by Martin Phillips on March 5, 2013 at 4:33 pm
    Ok – so this is my first FCPX project so finding my feet a bit ……
    Just wondered if it’s possible to add another text layer to a Basic or Custom title? I just want to be able to move the text lines around separately. Presumably if not I can just stack up title tracks? Thanks in advance.
    Martin Phillips Freelance Cameraman / Producer / Editor
    Chesham, Buckinghamshire, UK. http://www.videodvdmaker.co.uk
    Brett Sherman replied 13 years, 6 months ago 3 Members · 3 Replies
  • Lawrence Eaton
    March 5, 2013 at 6:48 pm
    Martin,
    Stack them up as you like; Edit their parameters, if you wish/ need and then right click to form a compound clip for efficiency’s sake.
    This might illustrate it in a simpler way: 5588_titles.png.zip
    Lawrence
  • Martin Phillips
    March 6, 2013 at 10:07 am
    Thanks Lawrence – that was just the job!
  • Brett Sherman
    March 10, 2013 at 12:44 pm
    You can right-click the title and open it in Motion. Then you can add as many text fields as you want and save it as a new title. If it’s a one-off then stacking is not a bad idea. But, if you need to do it continually then making a custom title will save you time.
