Activity Forums Maxon Cinema 4D Add Extension part to the output image
  • Add Extension part to the output image
    Posted by Tatra Tero on December 9, 2009 at 4:17 pm
    Hello,
    I have a problem here,lets say that i render an still architectural image 600*600 and then Decide to make it bigger lets say 600*900 (to add more landscape) but at same time i want to have all object at the same previous postion .
    (just i want to add extention image part to the original previous size 600*600).
    Tatra Tero replied 16 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    December 10, 2009 at 4:42 pm
    It’s possible to do by adjusting the camera’s focal length and film offset x/y parameters in proportion to the added dimensions. I believe you need to decrease the focal length by a multiple of the added dimension (e.g., if you double the x dimension, halve the focal length) and then adjust the corresponding offset by [.5(dimension change ratio)].
    So, for example, if you have a 1000×1000 render and a camera focal length of 50, and you changed the render dimensions to 2000×1000, with the new 1000 pixels offset to the right, you would then have to change the camera focal length to 25 and set the film offset X to 25%.
  • Tatra Tero
    December 10, 2009 at 6:45 pm
    thanks adam ,your reply help me a lot .
