Activity Forums Adobe After Effects Add Effect to Channel
  • Add Effect to Channel
    Posted by Jason Mckee on November 29, 2007 at 7:23 pm
    How would I go about adding an effect to just one channel? For example I am trying to find the best way to isolate just the blue channel and add a blur to it.
    Jason Mckee replied 18 years, 9 months ago 3 Members · 3 Replies
  • Kevin Camp
    November 29, 2007 at 8:40 pm
    try the effect channel blur, blur just the blue channel…
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Darby Edelen
    November 29, 2007 at 9:43 pm
    If you wanted to apply a more specific type of blur, such as Radial Blur, to your Blue Channel you would need to duplicate your layer and use the Channel > Shift Channels effect to set your top layer to have only Alpha and Blue enabled (Red & Green Full Off) and your bottom layer to have only Alpha and Red & Green enabled (Blue Full Off). Set your top layer to the Add blend mode and apply your Radial Blur to it.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Jason Mckee
    December 3, 2007 at 5:59 pm
    Thanks you guys. I knew it was something simple.
