Activity Forums Adobe After Effects Expressions Add effect, default properties panel to “closed”?
  • Add effect, default properties panel to “closed”?
    Posted by Bryan Woods on October 2, 2015 at 1:00 am
    Is there a way to tell the effect I’m applying to a layer (via script) to collapse its properties in the effects controls panel when its created? The effect I’m applying requires a couple different built-in effects that don’t necessarily need to be modified, but add a lot of clutter to the effects panel of the layer when all opened up.
    Bryan Woods replied 10 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
