Activity Forums Adobe Premiere Pro add edit jumps to previous frame before cutting
  • add edit jumps to previous frame before cutting
    Posted by Frank Feijen on August 10, 2017 at 10:20 am
    So I receive sourcematerial from my client, 1 mxf or mov with a number of shots concatenated.
    I go trough the clip, adding edits to seperate the shots. So I park my blue bar on the first frame of a new shot, hit the add-edit-button.
    And then it depends: sometime this works, other times the blue bar jumps back a frame, and adds the edit there.
    Any idea how to avoid this?
    Frank Feijen replied 9 years ago 2 Members · 2 Replies
  • Todd Perchert
    August 10, 2017 at 8:50 pm
    As Dave mentioned, I’ve seen this happen when frame rates don’t match.
    TC
  • Frank Feijen
    August 10, 2017 at 8:54 pm
    They do match… I just drop my videoclip onto the ‘make new sequence’ button to make sure that everything lines up nicely. The latest sourcefile that had this occuring was an MXF exported from Avid:
    MXF File details:
    Wrapper type: MXF OP1a (type: SingleItem SinglePackage MultiTrack Stream Internal)
    File generated by: AVID, TRMG (3.01)
    MPEG-2 422 Long-GOP
    I’m betting it’s the long-GOP thing, isn’t it?
