Activity Forums Adobe After Effects Expressions Add camera with 35mm preset and default position
  • Add camera with 35mm preset and default position
    Posted by Jake Hawley on August 15, 2010 at 8:22 pm
    Hey there. Two questions.
    I’ve looked around for a few hours but haven’t found anything that will allow me to add a camera and set it to 35mm.
    Also, Would like to position the camera at it’s default position. by default I mean how AE adds a camera when you do it through the menu bar.
    The script I’m working on is fairly simple. Adding a null and parented camera to an active comp. I’ve checked out a few camera rigging scripts but wanted something to how I already work with cameras.
    Jake
    app.beginUndoGroup("Camera and Null");
    var myComp = app.project.activeItem;
    ///CREATE CAMERA///
    var w = myComp.width /2 ;
    var h = myComp.height /2 ;
    var newCamera = myComp.layers.addCamera("Camera",[w,h]);
    ///CREATE NULL///
    var myNull = myComp.layers.addNull();
    myNull.threeDLayer = true;
    ///RENAMES NULL//
    myNull.name = "Camera Control";
    ///PARENTS CAMERA TO NULL//
    myComp.layer("Camera").parent = myNull;
    Jake Hawley replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
