Activity Forums Adobe After Effects “Add” Blending mode darkening edges unless BG layer exists
  • Max Haller
    August 4, 2022 at 10:05 pm
    I believe you understand how its working properly. The bit about it not knowing what to add that layers pixel data to because there’s nothing underneath.
    Have you tried using the choke matte effect to shrink the edges of the alpha? That could be enough to get rid of the dark edges if you play around with that and maybe a blur. Try choking the layer youre using as an alpha matte with that effect just a few pixels and it might be enough.
  • Alex Ezorsky
    August 5, 2022 at 2:29 pm
    Thanks for your reply. While technically choking the matte works, it’s not perfect as there is always either a little too much choking (causing the effect to not truly reach the edges of the layer) or too little choking causing the slightest darkening of edges.
    CURRENT SOLUTION: for anyone else struggling with this the only thing that seems to truly work is to use the wavy lines effect as a luma matte for an adjustment layer which I then place above my character and add to it a brightened curves effect. This would of course work the same if I replace the adjustment layer with a duplicate of my character but I prefer adjustment layers when possible. Bright lines and no darkening
    EPILOGUE: I would still love if someone at Adobe could give me like a root level programming explanation for this, I feel like this borders on a bug. Blending modes over semitransparent pixels (I’m guessing the semitransparent pixels at the edges of alpha are the culprit here) should still only do what they do over opaque pixels, i.e. only “add” if using “add” and not also darken. Rant over.
    Still happy to hear thoughts though!!!
  • Robert Müller
    August 8, 2022 at 4:54 pm
    Hey, yeah this has been an issue for ever and seems to be a core problem for every compositing software I used (e.g. Nuke). We used to have this problem with 3D renderings, here is my workaround (I hope I remember everything right. Real footage might give you some problems but I cant try it out right now)
    I usually go as follow:
    – precomposed the masked out/ keyed out footage, so you have one layer with no effects and masks, containing an alpha channel
    – apply the min/max effect set to maximum and “RGB+Alpha”, you dont have to go wild. This is to “expand the edges a little.
    – duplicate the layer and remove the effect (as I write this I realise, that you dont have to duplicate the original layer. A CC composite effect should work just fine)
    – above this goes the footage you want to screen/add/ whatever
    – on top of the stack goes another copy of the precomped footage with no effetcs, blending mode set to “Stencil alpha”
    Ive attached screenshots (sorry for german UI) to visualize the order better and a comparsion to your “old” method
    There a different ways to expand your footage a little bit, but this always worked for me. Hope I could help you out 🙂
  • Tristan Summers
    August 9, 2022 at 12:23 pm
    I am not sure you ARE understanding things properly.
    I would duplicate the person image and use tha as the matte for the wavy add layer.
    That is what you would do in any compositing software to limit the edges.
    I would Change the Transfer Mode of the wavy lines to Preserve Luminosity, then add a Shift Channels effect and take the alpha from luminosity, which is a nicer way to do it.
  • Walter Soyka
    August 10, 2022 at 4:17 pm
    Another option: use an Unmult effect to knock the black out to transparency.
  • Todd Perchert
    August 10, 2022 at 6:49 pm
