Activity Forums Adobe After Effects Add arrowhead to shape layer using trim paths & expressions?
  • Add arrowhead to shape layer using trim paths & expressions?
    Posted by Tim West on June 22, 2009 at 11:05 am
    I am trying to use expressions to attach an arrowhead to a shape layer.
    I’m using the ‘trim paths’ effect on the shape layer to grow a stroke over time (using the start/end/offset features).
    I would like to attach an arrowhead to the tip of the stroke, using an expression to animate it dynamically (e.g. the arrowhead follows the stroke when animated using the start/end/offset values)
    I’ve attached a basic project file if anyone can help?
    94_shapelayerarrowhead.zip
    Thanks for your time, any help appreciated 🙂
    Tim
    Tim West replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
