Activity Forums Avid Media Composer Add an additional clip to a group clip
  • Add an additional clip to a group clip
    Posted by Todd Sandler on June 5, 2014 at 1:29 pm
    Hi there-
    If I have a group clip consisting of 2 camera angles, is there a way to add a third angle without recreating a separate group clip?
    Additionally, if one of those angles are being linked via AMA, is there a way to relink that AMA angle to the transcoded master clip version once all the selects have been made?
    Appreciate your assistance in advance.
    Todd
    MC8
    OS 10.8.5
    2 X 3.2 QuadCore
    26GB RAM
    QT 7.6.6
    Blackmagic Intensity Pro
    Todd Sandler replied 12 years, 2 months ago 2 Members · 4 Replies
  • John Pale
    June 5, 2014 at 3:30 pm
    You can’t add a new angle to an already existing group clip in Avid. Hopefully, this feature will be added. Avid group clips are rock solid and have been for a long time, while other NLEs have struggled to get multicam working at all…but they have now fallen behind the competiton as far as features are concerned.
  • Todd Sandler
    June 5, 2014 at 3:35 pm
    Thanks, John.
    The reason I did it this way was that I didn’t want to wait for the transcode to begin working on my edit so I grouped an AMA file into my bin. The hope was to swap it out once I finished the transcoding. Being that isn’t possible, do you have any recommendations on achieving a similar solution so I dont have to continue working wiht an AMA in my group clip? I haven’t had the best of luck using AMA as a long term editing solution.
    Todd
    MC8
    OS 10.8.5
    2 X 3.2 QuadCore
    26GB RAM
    QT 7.6.6
  • John Pale
    June 5, 2014 at 7:39 pm
    If you relink the master clip to the transcoded file, using the relink dialog, does the group clip update and link to it as well?
  • Todd Sandler
    June 6, 2014 at 6:09 pm
    I relinked the transcoded file to my “selects” sequence in the bin. This sequence had the AMA’d group clip in the timeline and the AMA relinked to the transcoded file without a problem. Thanks for your assistance.
    Todd
    MC8
    OS 10.8.5
    2 X 3.2 QuadCore
    26GB RAM
    QT 7.6.6
