Activity Forums Adobe After Effects add a repeater on a shape layer on the Z axis?
  • add a repeater on a shape layer on the Z axis?
    Posted by Marc De coster on March 5, 2013 at 4:55 pm
    Hi guys.
    I’m working on a graphic design stuff and I have a question for you
    My animation begins with a simple circle. Then the circle multiply itself to, let’s say, 50 circles and all of them should be aligned on a ring. The diameter of the ring begins small and ends quite wide.
    So to multiply the circle, I wanted to add a repeater but the problem is that I can’t move these repeaters on the z axis or along a path, wich means that I can’t create my “ring of circles”
    I also tried to use a video copilot preset (the 3D orbit). I put it on a null, parent my circle to the null and align the orientation of the null along the path, etc … but I have to copy and paste 50 circles and I can’t work on the diameter of my “ring”
    Aaargl!!!!
    Does anyone know if I could do this with the repeater?
    Thanx
    Marc De coster replied 11 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Kevin Camp
    March 5, 2013 at 6:50 pm
    [Marc De Coster] “Does anyone know if I could do this with the repeater?”
    i don’t think so… as you’ve found, the individual shape (contents>’shape’) transform properties are only 2d, and thus the repeater only works in 2d.
    so i think you’re looking at creating 50 3d circle layers, offsetting their anchor points and rotating them around their x axis.
    to easily increase the radius of the ring, you can link the anchor points of the circles to the anchor point of a single circle with an expression like this:
    L = thisComp.layer(“Shape Layer 1”); // this would be your first circle, or master, etc..
    L.anchorPoint;
    if you keyframe the first circle’s anchor point, any circles with this expression will follow.
    if you need to control the x axis of all of them, i’d add an angle expression control effect to the first circle, and then try an expression like this to control the rest of the circles:
    L = thisComp.layer(“Shape Layer 1”); // this is your first circle
    i = L.index;
    L.effect(“Angle Control”)(“Angle”) * (index-i)
    you should then be able to control the x axis rotation of all the slave or follower circles from that one control.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Roland R. kahlenberg
    March 5, 2013 at 7:16 pm
    The Text Tool might be a viable option.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Vishesh Arora
    March 5, 2013 at 8:02 pm
    Marc
    Check this example:
    5590_animatingcircles.aep.zip
    Is that what you want?
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    2011 3D Demo Reel:
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Marc De coster
    March 6, 2013 at 9:16 am
    Mmmmmh, that’s exactly what I was afraid of … expressions !!!
    I know that some day I’ll be obliged to work on it but right now I know that expressions don’t like me 🙂
    I’ve tried what you told me but I must f*** up somewhere and it doesn’t work
    Well, I had a good night and I had a revelation! I’ll work with Element 3D! I’ll use my circle with no extrusion and then I’ll use the particle replicator. I’m sure it’ll make it
    Anyway, thanx a lot.
    I’ll post the result (if it’s good!!!)
  • Marc De coster
    March 6, 2013 at 9:18 am
    Yes I thought of that. Maybe letter O with a big stroke to fill the hole …
    I’ll try
    Thanx
  • Marc De coster
    March 6, 2013 at 9:20 am
    Thanx but no, it’s quite more complicated than that. The circles shouldn’t be flat and they should appear from the center of the ring
    But it’s OK I’ve found a solution
    Thank U
  • Pete Marshall
    June 17, 2015 at 9:09 am
    Would be nice to know what your solution was.
  • Marc De coster
    June 19, 2015 at 12:29 pm
    wow, that was an old one!
    You’re right, I should have kept you aware of what I did.
    As I said some posts earlier, I used Element 3D. I created a circle mask on a solid, extruded it in Element, added a replicator shape “ring” and animated the shape scale in the same time that the particule scale (that was also rotating on itself on the y axis if I remember well)
    I don’t have the result right here but I’ll try to find it back and post it
    Talk to you the next time I’ll have an issue, it’ll happen soon enough 🙂
    Marc
