Activity Forums Adobe After Effects add a football “bump” texture to background
  • add a football “bump” texture to background
    Posted by Zac on April 4, 2006 at 6:43 pm
    i need add a football texture to a background for a graphic. I have a photos but i need a pattern that is flat so that it will go smoothly across the background. I have tried to make a pattern but it looks like crap. Does anyone know where i can get a tutorial or ideas on how to create a texture like this? I am basically trying to add some texture behind some score text.
    Zac replied 20 years, 5 months ago 2 Members · 3 Replies
  • Scott Frizzle
    April 4, 2006 at 7:53 pm
    Give this a shot:
    https://www.scottfrizzle.com/temp/basketball_bump.jpg
    It’s a tileable (horizontally and vertically) basketball bump map that I made for a 3d basketball, but it should work fine for a football too. You could use it in conjucntion with a dark brown or leathery textured background to create the bumps you need. Let me know if this works for you.
    -scott
  • Zac
    April 5, 2006 at 11:02 am
    Awesome. That is exactly what i needed. Thank you so much.
  • Zac
    April 6, 2006 at 12:29 pm
    it works great, is there a way to get it to bulge out a little to add some depth? I have never used a displacement map before, is this what i would need to do to create the bumps to get some texture.
