Activity Forums VEGAS Pro Add a footage, background problem
  • Add a footage, background problem
    Posted by Leonardo Barone on December 2, 2015 at 4:29 pm
    Hello guys, yesterday I made a video with sony vegas, I simulated a pistol shooting, I recorder a video where I had in my hand a realistic pistol and I pulled the trigger, then I add on the video a one-frame of muzzle flash picture and was done, the fact is that when I add picture with black background everything is ok because the background don’t appear, but when I try to do the same with a footage something go wrong, infact also the background appear, but not black, it become a trasparent white, very disturbing.
    Here is an example, I took two pictures of my videos, I downloaded a footage of a spark with black backgound, how you can say in the second pictures when I add the footage the background appear but not black, it become a trasparent white, I don’t have any problem when I add pictures with black background, in this case the background don’t appear at all, but with the footage I have this problem, you can help me ? Thanks…
    John Rofrano replied 10 years, 9 months ago 3 Members · 5 Replies
  • John Rofrano
    December 3, 2015 at 1:01 am
    What makes you think that a black background should be transparent? What you need is a alpha mask. You can create one with the Mask Generator effect. Drop it on a copy of your clip that’s above the original and tune it to make the black really transparent. It will create a black and white mask that you can use to composite your video in Mask mode.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    December 3, 2015 at 1:12 am
    You can add some contrast to that Transparent white and tweak until its ok.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Leonardo Barone
    December 3, 2015 at 12:08 pm
    Thanks guys, when the background is black, the two advices you said work both,
    it could work also if the background will be green ?
  • Steve Rhoden
    December 3, 2015 at 12:21 pm
    it could work also if the background will be green ?”
    NO, Green is dealt with differently, by simply Chroma Keying.
  • John Rofrano
    December 3, 2015 at 12:40 pm
    Yea, once you involved color, you want to use the Chroma Key. For black and white you would use a Luma Key (which is what the Mask Generator is creating).
    ~jr
