Activity Forums Adobe After Effects add a definied comp in another comp with javascript
  • add a definied comp in another comp with javascript
    Posted by Phil Largilliere on April 11, 2016 at 9:27 am
    Hi every one
    I wrote a script where I create a new comp, then I want to import a definied comp in this new one, but I can’t find the way to do this.
    myProject = app.project;
    myProject.items.addComp("surComp",1920,1080,1,15,25);
    var myComp = new Array();
    for (i=1; i <= myProject.numItems; i++)
    if (myProject.item(i).name == "Comp 1")
    { myCompNum = i - 1;
    if (myProject.item(i).name == "surComp")
    myProject.item(i).openInViewer();
    //Add "Comp 1" as layer in this new Comp ???
    Can you help me ??
    Thank you so much
    PH…
    Phil Largilliere replied 10 years, 4 months ago 2 Members · 2 Replies
  • Walter Soyka
    April 11, 2016 at 10:13 am
    You use the .add() method of a LayerCollection:
    surComp = myProject.items.addComp("surComp",1920,1080,1,15,25);
    { comp1 = myProject.item(i);
    surComp.openInViewer();
    comp1Layer = surComp.layers.add(comp1);
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Phil Largilliere
    April 11, 2016 at 10:32 am
    Thank you !!
    it works perfectly well !! I use to write this code, but I don’t know why it doesn’t work. Thanks again 😉
