Activity Forums Adobe After Effects Expressions Add 10% brightness to shape layer fill HSB
  • Add 10% brightness to shape layer fill HSB
    Posted by John Cuevas on January 3, 2024 at 7:41 pm
    I’m trying to use the fill color from one shape layer, input it into another shape layers fill layer, with a 10% boost to the brightness of the HSB. I been working with ChatGPT, but I keep getting the same input error on line 1. “object of type found where a Number, Array, or Property is needed”
    Any ideas?
    // Assuming “color” is the input color property
    inputColor = color; // Replace “color” with your actual color property
    // Convert color to RGB
    rgbColor = [inputColor[0]/255, inputColor[1]/255, inputColor[2]/255];
    // Extract HSB components
    h = rgbToHsl(rgbColor)[0];
    s = rgbToHsl(rgbColor)[1];
    b = rgbToHsl(rgbColor)[2];
    // Calculate new brightness with a 10% increase
    brightnessIncrease = 0.10;
    newBrightness = clamp(brightnessIncrease + b, 0, 1);
    // Convert back to RGB
    newColor = hslToRgb([h, s, newBrightness]);
    // Return the new color
    newColor
    // Function to convert RGB to HSL
    function rgbToHsl(rgb) {
    var r = rgb[0];
    var g = rgb[1];
    var b = rgb[2];
    var max = Math.max(r, g, b), min = Math.min(r, g, b);
    var h, s, l = (max + min) / 2;
    if (max == min) {
    h = s = 0; // achromatic
    } else {
    var d = max – min;
    s = l > 0.5 ? d / (2 – max – min) : d / (max + min);
    switch (max) {
    case r: h = (g – b) / d + (g < b ? 6 : 0); break;
    case g: h = (b – r) / d + 2; break;
    case b: h = (r – g) / d + 4; break;
    h /= 6;
    return [h, s, l];
    // Function to convert HSL to RGB
    function hslToRgb(hsl) {
    var h = hsl[0];
    var s = hsl[1];
    var l = hsl[2];
    var r, g, b;
    if (s == 0) {
    r = g = b = l; // achromatic
    } else {
    function hue2rgb(p, q, t) {
    if (t < 0) t += 1;
    if (t > 1) t -= 1;
    if (t < 1 / 6) return p + (q – p) * 6 * t;
    if (t < 1 / 2) return q;
    if (t < 2 / 3) return p + (q – p) * (2 / 3 – t) * 6;
    return p;
    var q = l < 0.5 ? l * (1 + s) : l + s – l * s;
    var p = 2 * l – q;
    r = hue2rgb(p, q, h + 1 / 3);
    g = hue2rgb(p, q, h);
    b = hue2rgb(p, q, h – 1 / 3);
    return [r * 255, g * 255, b * 255];
    John Cuevas replied 2 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 3, 2024 at 7:58 pm
    Maybe like this:
    c = thisComp.layer("Shape Layer 1").content("Rectangle 1").content("Fill 1").color;
    hsl = rgbToHsl(c);
    newL = Math.min(hsl[2]*1.1,1);
    hslToRgb([hsl[0],hsl[1],newL,hsl[3]])
  • John Cuevas
    January 3, 2024 at 8:03 pm
    Dan you are the best!!!
