Activity Forums Adobe After Effects Expressions Adaptive position based on sourceRectAtTime?
  • Adaptive position based on sourceRectAtTime?
    Posted by Kieran Lefort on June 10, 2019 at 10:03 am
    I’m creating a lower third where the bar with the text on emerges from behind another shape and has a Dan Ebberts bounce on the end position keyframe. The text bar width adapts to the size of the text using sourceRectAtTime. Cool. Easy.
    The problem I’m having is that when the text and therefore the bar gets long, it starts off sticking out from behind the shape. “Just move the starting position keyframe,” I hear you shout.
    Not that easy.
    Moving the starting keyframe changes the velocity of the animation, thereby affecting the bounce and producing an undesired effect.
    I think what I need is an expression that both alters the starting keyframe’s position based on the value delivered by the text’s sourceRectAtTime and the amp variable of the existing bounce expression.
    I think there’s a lot of maths I can’t begin to understand going on here. Grateful for any help.
    Griffin Englander replied 7 years, 2 months ago 3 Members · 3 Replies
  • Kalleheikki Kannisto
    June 11, 2019 at 4:35 am
    “Just make the text smaller!”
    Without seeing any of the expressions involved, that is what I have to say.
    Senior Graphic Designer
  • Kieran Lefort
    June 11, 2019 at 12:43 pm
    Hahaha! If I could, I would. Unfortunately, this has to conform to a strict design.
    I’ve found a different animation for this particular project, but I’m still interested in any solutions to this problem as it’s bound to come up again.
  • Griffin Englander
    July 10, 2019 at 6:11 am
    What speed is the start of the animation? If it’s fast you can probably get away with only activating the layer when it’d be visible.
    Or, I’m not sure how you’ve set-up the box, but you could do a little anchor point animation on the text to gradually/ noticeably offset the text without affecting your position animation/ bounce.
    Just some quick, tired thoughts.
