Activity Forums Adobe Premiere Pro Adaptive Audio questions
  • Adaptive Audio questions
    Posted by Gary Gardner on July 10, 2014 at 7:58 pm
    So, I’m using PPCC adaptive audio in my timeline (6 mono recordings within one audio track in the timeline). Two questions for you all…
    1) If I want to only play/use one of the 6 mono tracks, how do I do that?
    2) I’m a little confused by the audio playback… When I look at the ‘audio meter’ window, does it default to play all of the tracks (and all of the mono recordings)? I know I can select one of them and it will only play one of the mono recordings, so I’m having a hard time figuring out how this all works.
    Any advise is appreciated.
    Dennis Radeke replied 12 years, 2 months ago 2 Members · 1 Reply
  • Dennis Radeke
    July 11, 2014 at 8:58 am
    Adaptive Audio tracks are primarily for cameras that record more than 2 channels of audio and is generally used most when needing multi-channel audio output from your sequence.
    Premiere Pro Audio overview
    If you’re outputting your sequence to stereo, you can probably use Standard tracks (which can contain either stereo or mono material.
