Activity › Forums › Blackmagic Design › Adaptec RAID 1430SA
Adaptec RAID 1430SA
Posted by Phil Harbath on March 13, 2007 at 6:38 pmwill this raid card to the trick (4 port sata pci-e). i would like to stick it in the sli slot
i am not using. just to clarify i will be doing standard def work.phil
Alex Rinquest replied 15 years, 11 months ago 4 Members · 5 Replies -
Bob Zelin
March 13, 2007 at 9:45 pmI don’t know this card, but the industry standard SATA cards are from Cal Digit, Sonnet and Firmtek. They all work wonderfully, and are all under $300.
Bob Zelin
Phil Harbath
March 13, 2007 at 10:08 pmif someone had a good experience with a specific card for PC, i would
be grateful. preferably 4 port.thanks
phil -
Pelle Ferner
March 14, 2007 at 1:58 pmI have a adaptec raid 1420SA in pci-x slot in my machine and It
Bob Zelin
March 14, 2007 at 3:44 pmCal Digit Fasta 4x
Cal Digit Fasta 4e
Sonnet X4P
Sonnet E4PAll 4 cards listed above are under $299.
bob Zelin
Alex Rinquest
September 27, 2010 at 10:06 amYou started your post and then did not complete it. I have an Adaptec 1420Sa with 4 x 1 Sata drives. I am running Win 7 64bit. My supplier installed the drives and the card. While on booting up I am able to see the two raid drives and their configuration- that’s as far as it gets. I cannot see them on the desktop. I have emailed Adaptec but have no response after two weeks. There is a convoluted linus setup CD which requires a floppy disk(to create a driver disk) but sadly I have no floppy drive. The Adaptec Driver CD boots up but then hangs with 4 penguins and many rows of dots. Yes I am taking this back to the installer but it would be so much more convenient if anyone could advise me how to get these drives on the desktop. Have had no problems at all with adaptec on my Media 100 and Mac – this is the first.
Many thanks
