Activity › Forums › DaVinci Resolve › Actual Benchmarks on GTX 680’s in Resolve?
Margus Voll replied 13 years, 10 months ago 10 Members · 30 Replies
Rohit Gupta
June 19, 2012 at 6:33 amHere’s the deviceQuery for the 580:
Total amount of global memory: 1536 MBytes (1610285056 bytes)
(16) Multiprocessors x ( 32) CUDA Cores/MP: 512 CUDA Cores
GPU Clock rate: 1544 MHz (1.54 GHz)
Memory Clock rate: 2004 Mhz
Memory Bus Width: 384-bit
L2 Cache Size: 786432 bytes -
Juan Salvo
June 19, 2012 at 1:34 pmLooks like a stock 580. Thanks for posting Rohit. Interesting, so the overclocked 680 has performance similar to that of a standard 580. I’d imagine then the best or one of the best performing cards for resolve might be an overclocked 580. Like the GTX 580 3gb classified. Of course that card could never run in a MacPro, it would require too much power and produce too much heat. But for those running cubix or going to windows, looks like a good choice.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
Jeremiah Belt
July 12, 2012 at 2:21 pmI’m torn…I can get the new 680 4GB for $20 more than the 580 3GB. Soo 3×580 3GBs or 3×680 4GBs on Windows for Resolve, After Effects, & Premiere work? Would the 4GBs of memory each bring the performance closer to the 580s?
Jeremiah Belt
July 14, 2012 at 6:49 amHey Rohit. Im about to pull the trigger in my workstation. I missed my window to buy some 580s and now I have to get used or pay over $600 for the 3GB versions. I’m thinking of just buying three GTX 680s with 4GB of ram each and hoping for the best. Any new performance comparisons or benchmarks in Resolve with 680s? Hoping the 4GBs will get them a bit closer to the 580s.
Juan Salvo
July 14, 2012 at 11:19 pmIf you’re getting three of them I don’t think the performance hit will be huge between the 580s and 680s as with that many devices you start to run into a bandwidth bottle neck on performance.
Colorist | Online Editor | Post Super | VFX Artist | BD Author
Jeremiah Belt
July 15, 2012 at 7:37 amThanks, that’s what I’m hoping. Bought 3 of them today (1 for GUI and 2 for GPUs). Ended up buying the Galaxy GTX 680 4GBs due to their custom coolers reported to be quieter than the competition. Bought a board that should be able to utilize all three cards at full 16x bandwidth on PCIe 3.0 slots. Hoping for the best.
André Finotti
August 9, 2012 at 9:52 pmHi Jeremiah,
I’m going in the same path, Windows + GTX 680 or 580.
So, after all, what are your impressions?
Jeremiah Belt
August 9, 2012 at 10:14 pmWell I’m still in process sadly. Turns out when you buy bleeding edge cpus they are hard to cool. I’m on my fourth set of heatsinks. Here’s to hoping these work. Should be another week or two before I have it all stress tested and all 3 GTX 680s in there. I will let ya know. Thx.
Reuben Fink
November 8, 2012 at 4:35 amI have the same 570 card. Did you feel that the MacVidcards upgrade was worth the extra cost. I was under the impression you would only gain boot screen advantage not a noticeable speed increase after the upgrade. Did you notice quite a change?
OSX 10.8.2
Equipment: 2.8 ghz 8 core Intal Mac Pro 3,1 Early 2008, 20 gig of ram
Aps: CS6 Production Premium, FCP Suite, Avid Media Composer -
Margus Voll
November 8, 2012 at 7:19 amIn tech sense there should be difference as regular pc runs had the speed of macvids one on data bus.
Margus
DaVinci 9, OSX 10.7.4
MacPro 5.1 2×2,93 24GB
GTX 470 / Quadro 4000
Multibridge 2 Pro
