Activity Forums Media 100 Activation Key
  • Activation Key
    Posted by Jim Mclean on December 9, 2008 at 5:25 pm
    I have put an older p6000 card into G5 Media 100i system. I have the serial number and activation key and when I enter the activation key I’m told the number is invalid. What do I need to do to make the system work with this p6000 card. (That I know works from another system).
    Floh Peters replied 17 years, 9 months ago 2 Members · 3 Replies
  • Floh Peters
    December 9, 2008 at 6:03 pm
    [Jim McLean] “I have put an older p6000 card into G5 Media 100i system. I have the serial number and activation key and when I enter the activation key I’m told the number is invalid. What do I need to do to make the system work with this p6000 card. (That I know works from another system).”
    The activation key is related to a software version; e.g. there is a key for V8.0 to 8.1.x, a key for 8.2,… I guess you simply use the wrong software for the key; most likely V8.2.3a when your key is only for 8.1.x
  • Jim Mclean
    December 9, 2008 at 8:17 pm
    Josh,
    We had another P6000 die in our G5 which has 10.4 on it. We have an older Media 100i running on a G3 we no longer use. We put the card from the G3 in the G5. The G3 was running version 7.5 and I guess the key is from that version. Can we buy a key that will unlock the old P6000 to run in the G5 with version 8.2.2? Thanks for your help. Jim
  • Floh Peters
    December 9, 2008 at 8:22 pm
    [Jim McLean] “Can we buy a key that will unlock the old P6000 to run in the G5 with version 8.2.2? Thanks for your help. Jim”
    Yes you can. But not from me. 😉
    You should get in touch with Media 100 sales, they can sell you an unlock key for 8.2.3 for your P6000 board.
