Activity Forums Adobe After Effects Expressions Activate/DeActivate A parent using a checkbox
  • Activate/DeActivate A parent using a checkbox
    Posted by Max Souliers on March 18, 2025 at 2:21 pm
    Hi AE Expression Wizards! I’m looking for an expression to use a “checkbox” to activate and/or deactivate a parent. For example, I separated the X and Y positions on the Parent layer AND on the child layer. Then, I put a checkbox control on my child layer. And I wanted to add an expression on the X and/or the Y position to parent the child layer position to the parent layer position only when I check the checkbox. Otherwise, my child doesn’t follow the parent. Could you help me??? Thank You in advance.
    Dan Ebberts replied 1 year, 6 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    March 18, 2025 at 7:13 pm
    See if this works – take note that it doesn’t account for keyframing the checkbox which will result in position jumping –
    for xPosition –
    if (effect(“Checkbox Control”)(“Checkbox”) == 1 || thisLayer.parent == null) {
    // When checked or no parent, use normal/parented position value
    value;
    } else {
    // When unchecked, counteract parent’s position
    parentLayer = thisLayer.parent;
    // Get parent’s world position at current time
    parentWorldPos = parentLayer.toWorld([0,0]);
    // Get parent’s world position at time 0 (initial position)
    parentWorldPosT0 = parentLayer.toWorld([0,0], 0);
    // Calculate parent’s position change
    parentDeltaX = parentWorldPos[0] – parentWorldPosT0[0];
    // Subtract parent’s movement from our current position
    value – parentDeltaX;
    for yPosition –
    value;
    } else {
    parentDeltaY = parentWorldPos[1] – parentWorldPosT0[1];
    value – parentDeltaY;
  • Dan Ebberts
    March 18, 2025 at 7:17 pm
    This may not be what you’re after, as it requires the checkbox to be keyframed to on when you want the child’s x position to follow changes in the parent’s x position:
    p = thisComp.layer("parent").transform.xPosition;
    cb = effect("Checkbox Control")("Checkbox");
    accum = value-value;
    if (cb.numKeys > 0){
    n = 0;
    n = cb.nearestKey(time).index;
    if (cb.key(n).time > time) n--;
    if (n > 1){
    if (cb.key(n).value) accum += p - p.valueAtTime(cb.key(n).time);
    for (i = n-1; i > 0; i--){
    if (cb.key(i).value) accum += p.valueAtTime(cb.key(i+1).time) - p.valueAtTime(cb.key(i).time);
    if (cb.key(1).value) accum += p.valueAtTime(cb.key(1).time) - p.valueAtTime(0);
    }else{
    if (cb.value) accum = p - p.valueAtTime(0);
    value + accum
