Activity › Forums › Adobe After Effects › Action Scripting for AE
Posted by Moog_mama on December 10, 2005 at 8:59 pmIs it possible to script AE like Flash: onclick go url?
“The secret to creativity is knowing how to hide your sources.”
Julius Ngeru replied 18 years, 7 months ago 4 Members · 3 Replies -
Filip Vandueren
December 11, 2005 at 2:22 amNo…
AE outputs movies, movies don’t respond to clicks (the play button in your movieplayer does)
However, you can create markers in a track (by hitting alt-asterisk *) and enter a URL to that marker.
There are a few output-options that will use that URL when the movie is played back and you get to the frame where that marker was placed.
I believe only
File->export->Macromedia Flash (SWF)… (if you set the “include Layer marker Web Links” option)
And QuicktimeThe quicktimes will only do the webjump if the movie is actually played from within a webbrowser, not when it’s played from the movieplayer…
Jim Kanter
December 12, 2005 at 1:41 amYou can write expressions to control animation, but it isn’t an interactive environment that the user can control.
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com -
Julius Ngeru
March 5, 2008 at 12:18 amIf I select”include Layer marker Web Links”, how do I use them in Golive. Please help.
