Activity › Forums › Apple Final Cut Pro Legacy › Action safe for all monitors?
  • Action safe for all monitors?
    Posted by Heidi Schrodinger on October 9, 2012 at 11:26 pm
    Hello again!
    I have finished a 30 min short film and am about to export and burn to disc.
    When I was at the sound mixer ( which was a waste of time and money as FCPX does NOT support an export of OMF files for use in Pro tools….. if I had known this I would not have bought and used FCPX- how ridiculous )…anyway, when I was at the sound guys studio, I noticed that my quicktime movie for reference was showing ALL the image on the monitor.
    So the edges of the video- under still photos, etc, were still showing up where I thought the outside of the viewing area should be.
    Is there something I should be doing on or before output to make sure this doesn’t happen?
    It is a PAL SD project and I will be exporting with Pro Res 422.
    Heidi
    ‘Getting back into making after a long time off’
    Heidi Schrodinger replied 13 years, 11 months ago 3 Members · 4 Replies
  • Eric Strand
    October 10, 2012 at 1:56 pm
    This isn’t related to your question per say but in regards to FCPX to Pro Tools, there is a tutorial on Lynda that is just for that. I know it’s too late for your current project, but maybe in the future it will help.
    https://www.lynda.com/Final-Cut-Pro-tutorials/Audio-Post-Workflow-Final-Cut-Pro-X-Pro-Tools/103055-2.html
  • Heidi Schrodinger
    October 11, 2012 at 12:07 am
    ooh, thanks for that… will be used in the future no doubt. I was so surprised at this failure by FCPX….really unprofessional. no that I am a professional 😉
    as for my other question, I realise now I have misunderstood what action safe actually means. So I had to resize a bunch of images..but no worries, it’s done now, film looks great ( and sounds crappy )
  • Shane Ross
    October 11, 2012 at 12:35 am
    If you can see it in the Canvas, no doubt someone will see it on their TV/monitor. You need to assume that they can see that…because they might be watching a QT file on a computer which shows you EVERYTHING. The TV safe guides are for…well…TVs. And OLD ones too. Tube TVs where there was a lot of plastic overlapping to hold that tube in. Later TVs…HDTVs…have a lot less holding that back, so you can see more of the picture.
    I always play it safe, assume people can see everything I see in the canvas. The Safe guides are areas that are GUARANTEED to be seen.
    Shane
    Little Frog Post
  • Heidi Schrodinger
    October 11, 2012 at 2:57 am
    ThanksShane… this explains it well… I thought it the other way- that action outside would not be seen! Thanks so much,
    Heidi
