Activity Forums Adobe Photoshop Action repeat on Image Sequence
  • Action repeat on Image Sequence
    Posted by Fargoross on August 2, 2006 at 2:34 pm
    I apologize if this question has already been answered, I’ve searched quite a bit and have come up with nothing.
    I want to apply a series of filters to images that are part of an image sequence (Video Essentially)
    I know how to make an action, and I have done so, so that I only have to click ‘play’ and my image gets its filters applied and then closes.
    But I would like to take this one step further, and not have to click play 300 times for 300 images (or 10 seconds of video).
    I am able to open up to about 300 at a time in PhotoShop. So I would like to figure out how to let my action repeat to all of
    the open files, so I can click once, and go do something else. There must be some way of doing this..??..
    thanks for the help!
    -Ross Hendrickson
    Editor, Video Arts Studios
    Kim Mackenzie replied 20 years, 1 month ago 3 Members · 2 Replies
  • Richard Harrington
    August 2, 2006 at 2:40 pm
    Record an action then run a batch command
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
  • Kim Mackenzie
    August 2, 2006 at 2:41 pm
    You’re looking for File > Automate > Batch. Once your action is recorded, this is the way to apply it to an entire folder worth of files.
    The settings will vary depending on your needs, but you’ll have to play with the desintion (i.e., save and close, or save to another folder). One thing that trips people up is the “Ignore Action Open” and “Ignore Save As” – basically, if your script includes opening the original file, you need to check “Ignore Action Open” – otherwise, the script will run on the same file over and over. If your script included you saving the file, check “Ignore Save As.” That way, if part of your script was to save as a different format, it will retail the format change part of teh action, but it won’t use the same filename over and over.
    It’ll make more sense when you try it. I always back up my files first before running a big batch. If you get stuck, you can look in the help for Batch.
