Activity › Forums › Adobe After Effects › Action Essentials 2 problem.
  • Matt Doe
    May 25, 2011 at 5:52 pm
    Could be a scale issue, if you bought the 720p version and are putting that into a 1080 comp, you’ll see the hard edge of the action essentials material as it is only at 720p.
  • Gaston Barbero
    May 25, 2011 at 6:18 pm
    Keeps failing =/
    Shame not accepted ^^
  • Matt Doe
    May 25, 2011 at 7:29 pm
    Failing? What do you mean?
  • Gaston Barbero
    May 25, 2011 at 7:49 pm
    I will thanks
