Activity › Forums › Apple Final Cut Pro Legacy › acoustilock cabinet for silence
Posted by Andy Edwards on May 18, 2005 at 6:00 pmIs anyone using a acoustilock cabinet for their bay?
https://www.acoustilock.com/acl24sf.htmlI wondering what you have to do to vent the air if you do not keep your in room AC down at 65 degrees. Opinions on the box, comments etc. all appreciated.
Andy
Mitchji replied 21 years, 4 months ago 4 Members · 7 Replies -
John Fishback
May 18, 2005 at 6:52 pmWe use a room adjacent to our edit suite as a machine room. We cool both rooms with the same system year-round. PVC conduit through the wall at two places stuffed with foam to make the pass-throughs virtually airtight. The cable run from computer to keyboard and monitors is about 10 feet. And we have no noise in the edit suite. Be sure to make the wall between the machine room and suite as airtight as possible. Caulk cracks where necessary. Air through cracks transmits a lot of noise.
John
Dual 2.5 G5 4 gigs RAM OS 10.3.8 QT6.5.2
Dual Cinema 23 Radeon 9800
FCP4.5 DVDSP 3.0.2
Huge U-320R 1TB Raid 3 firmware ENG12.BIN
ATTO UL4D driver 3.20
AJA IO driver 1.3.1 firmware v21-26
SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors -
Andy Edwards
May 18, 2005 at 7:26 pmThe room situation I am considering will not allow for a machine room next door. I totally agree with you that this is a great way to approach it for silence, but this situation won’t allow it. This is one reason I was looking at the acoustilock cabinet for in room silence. I’m just worried that it won’t be able to vent the air properly unless you pump the cabinet air out of the room.
Thanks for your input.
Andy
John Fishback
May 18, 2005 at 7:37 pmI looked at the acoustilock website and it’s ambiguous about how to get air into the cabinet. It seems to imply that it will extract the room air. I suppose you could drop a vent down in the wall to where the cabinet will be and so direct more air at the cabinet intake. You might even run a soft duct from the a/c vent to the air intake of the cabinet.
John
FCP4.5 DVDSP 3.0.2
Andy Edwards
May 18, 2005 at 7:48 pm[JRF] “It seems to imply that it will extract the room air.”
That was my first concern. If your room reaches a certain temp and you are not running an AC unit 24/7, does it just recycle the same hot air spewing from the back of your computers and over heat everything.
I use to run one of these in a closet I made into my machine room:
https://shop.howstuffworks.com/products/APC+NetworkAIR+AP7003+Air+Conditioner/SF-1/PID-20743213It worked well, but now I am a new location with no closet to stick it into to.
I just don’t want to spend $2,000 on a cabinet to get rid of the Computer noise and have heat issues kill all the silence 🙂
Well the search continues.
Jeff Carpenter
May 18, 2005 at 8:55 pm$2,000?
Nah, all you need is a nice cool substance to conduct the heat away from the system. Why not take your computer apart and re-build it in an aquarium of vegetable oil?
https://www.markusleonhardt.de/en/oelbilder.html
Andy Edwards
May 18, 2005 at 9:08 pmNow that is hilarious!!
Now I have an idea of how to keep my server farm cool. Get that drum of corn oil and dunk it all. 🙂
Mitchji
May 19, 2005 at 5:21 am[Andy Edwards] “That was my first concern. If your room reaches a certain temp and you are not running an AC unit 24/7, does it just recycle the same hot air spewing from the back of your computers and over heat everything.
“Hi,
I looked at these at a trade show. Excellent quality! The box is not going to be worse than the bare computer in terms of recycling heat. A computer pulls in room air and exhausts hot air back into the room. The box will do the same thing. If the room gets so hot that this is an issue you probably won’t be able to get any work done anyway. So I don’t think thats an issue.
Best Wishes,
Mitch
