Activity › Forums › Adobe After Effects › achieving this text extrude animated effect
  • achieving this text extrude animated effect
    Posted by Wilson Costa campos on June 23, 2016 at 10:37 am
    Hi everyone,
    I was trying to achieve this sort of effect that can be seen at https://vimeo.com/146869349 at around 2:42s
    Played a lot with after effects but couldn’t get the right look..
    Seems to be a directional blur but can’t get quite the same effect. could it be that it has a mask? but that would require a lot of work..
    if anyone knows or has an idea I would immensely appreciate it!
    Kind Regards!
    Wilson
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Wilson Costa campos replied 10 years, 3 months ago 5 Members · 6 Replies
  • Walter Soyka
    June 23, 2016 at 11:36 am
    I’d guess this was originally done in a 3D app, but you could pull off something similar with a fake 2.5D extrusion in Ae — set up many stacks of layers for each letter, offset by a single pixel or less in X, Y and Z.
    Something like this script could be helpful:
    https://aescripts.com/3d-extruder/
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Joe Clay
    June 23, 2016 at 3:10 pm
    Interesting, I wrote a plugin with similar functionality. It has some bugs I haven’t been able to fix so I haven’t released it yet. :/
    Anyway, you might be able to get away with a few directional blurs, and some masks on the opposite side of the text. You’ll probably have to precomp it to do that.
    Joe Clay
    Workbench.tv
  • Kalleheikki Kannisto
    June 23, 2016 at 3:14 pm
    Here’s a fun one for you. Duplicate the layer a bunch of times (about 8) and see what happens…
    10219_blurtrail.aep.zip
  • Daniel Waldron
    June 23, 2016 at 4:14 pm
    You could also try messing around with a long shadow technique and some masking. Probably won’t achieve the exact look in the video this way though.
  • Wilson Costa campos
    June 23, 2016 at 4:29 pm
    thanks a lot for this! I found another way with trapcode starglow too but not quite the same
    June 23, 2016 at 5:26 pm
    thanks daniel it is very similar to this!
