Activity › Forums › Adobe After Effects › Achieving that 8mm look
Posted by Lazlonius on December 28, 2005 at 7:29 pmDoes anyone know of a good way via a plug-in or otherwise to get close to that 8mm film look from normal dv footage? Any help would be appreciated. Thanks
Chris Smith replied 20 years, 9 months ago 2 Members · 4 Replies -
Chris Smith
December 28, 2005 at 8:23 pmPlease check the archives for “8mm”. It’s been talked about a LOT in the past. You should find some good recip
Lazlonius
December 28, 2005 at 9:02 pmThanks Chris I tried looking but didn’t see anything before. I’ll go back again.
Chris Smith
December 28, 2005 at 9:17 pm2 notes. Actually make sure the posterize time is first in the stack. Also I was wrong about noise. More like 20 – 30 instead of 5ish.
Chris Smith
https://www.sugarfilmproduction.com -
Chris Smith
December 28, 2005 at 9:25 pmhttps://sugarfilmproduction.com/8mm.ffx
I posted my preset. I’m sure you will have to modify the levels and sat a bit for your footage.
This is for AE 6.5. Select your layer. Go to the Animation Menu. select APply animation preset and select this preset.
Chris Smith
