Activity › Forums › Apple Final Cut Pro Legacy › Achieving specs for broadcast
  • Achieving specs for broadcast
    Posted by Jana Leveritt on July 30, 2009 at 5:11 pm
    I have to export a spot for broadcast from FCP and would like to deliver digitally. The specs I have received are as follows:
    720×480
    4:3
    29.97 frame rate
    6Mb min bit rate
    48Khz audio
    They can accept Quicktime, Mpeg2 or AVI files. Also, they request if exporting a Quicktime to use the H.264 compression to encode and the highest quality two pass setting.
    I usually deliver on tape but can cut out a substantial cost in this case if I deliver spots digitally. Any help would be greatly appreciated. I’ve tried a number of things over the past 24 hours and have not achieved the right combination yet.
    Thanks in advance…
    Jana
    Chris Poisson replied 17 years, 2 months ago 2 Members · 1 Reply
  • Chris Poisson
    July 30, 2009 at 7:47 pm
    It sounds like your settings are pretty clearly mapped out, you should be able to get a decent H264 QT from QuickTime Pro, otherwise use Episode.
    Have a wonderful day.
