Activity Forums DaVinci Resolve ACES Render
  • ACES Render
    Posted by Jon Dobson on March 14, 2012 at 4:43 pm
    Hi there,
    I have finished grading a project and I am rendering out as usual to an uncompressed quicktime.
    However, I graded this project on the ACES colour science and now when I export the video file created is black crushed. (I have tried codecs too inc pro res)
    Do I need to apply an outgoing ACES LUT to convert the colour space back to RGB?
    Thanks in advance,
    Jon
    Jon Dobson replied 14 years, 6 months ago 3 Members · 3 Replies
  • Dan Moran
    March 14, 2012 at 5:14 pm
    Hey Jon,
    Have you made sure to have the Rec709 output transform on when grading?
    It should all flow nicely for you then.
    Hope this helps!
    D
    Dan Moran
    DaVinci Application Specialist
    Blackmagic Design EMEA
  • Chris Martin
    March 14, 2012 at 5:37 pm
    Assuming you were grading in rec709, 64-940, it sounds like you’re getting quicktimes that are getting stretched to full range (0-1023) rather than SMPTE (64-940).
    If you graded in rec709 then hopefully you had rec709 selected as an output device transform in the settings.
  • Jon Dobson
    March 14, 2012 at 8:19 pm
    Ah I see!
    Thanks for the help!
    Jon
