Activity Forums DaVinci Resolve ACES REC709 Highlights
  • ACES REC709 Highlights
    Posted by Daniel Davila on November 25, 2014 at 7:03 pm
    Hello, I’m working with ACES in V11 and the RED material works fine, but I’m having trouble with REC709 video, I use REC709 IDT and the image looks fine, but the highlights and clipping iare TOO MUCH bright, if I try to take it down with a grade I have to make the rest of the image almost black and still there’s some weird color clipping. I’m also doing some NUKE compositing and I export EXR sequences from RESOLVE, the same, in NUKE they look fine, in the 0 to 1 value range, but the highlights go up to 15!
    At some point I’ve managed to work over, but I can’t even make a dissolve to black inside RESOLVE, the last frames near the black there are weird clipping colors.
    I think REC709 on ACES should be a straightforward thing, so if anyone is using it without problems please let me know.
    Thanks!!
    Daniel Davila replied 11 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
