Activity Forums Adobe Premiere Pro ACEDVio Question
  • ACEDVio Question
    Posted by Wasteland on August 20, 2005 at 8:42 pm
    I have a Dell dimension 3000, Premier pro 1.5, and Canopus ACEDVio. My question is, is it possible to capture video to an external fire wire hard disk? and if so does it matter what kind of external hard disk I buy?
    Seth Hancock replied 21 years, 1 month ago 2 Members · 1 Reply
  • Seth Hancock
    August 22, 2005 at 7:18 pm
    Are you talking about capturing directly from the camera or from the computer. If you are trying to capture from the computer to an external hard drive the you will somehow need a device that triggers the play/record/stop, etc. functions. I believe the FireStore device can do this. You can always shoot and capture to this external hard drive then connect that device to your ACEDVio and work like normal. Does this answer your question? If not, then please provide a little more clarity as to what you are exactly trying to accomplish.
    Here’s the link to that device.
    https://www.focusinfo.com/products/firestore/fs-4.htm
    Seth
    wordtoyomutha
