Activity › Forums › VEGAS Pro › ACEDVio ( How to set Audio Out from DV connector)
  • ACEDVio ( How to set Audio Out from DV connector)
    Posted by Haizad on October 20, 2007 at 5:37 am
    Hi all,
    My name is Haizad
    I have 2 question:
    1) Really need your guys help. Before this I`m using Canopus Let`s Edit and this ACEDVio card. Its work well (mean I can monitor my picture & audio at my external TV)
    But after switch to Sony Vegas, I can only get Picture at my external TV. CANNOT get sound.
    Below is my connection from the ACEDVio card.
    Video Out: Yellow RCA go to my LCD Video In(Yellow)
    Audiot Out: Red & white RCA go to my LCD Red&White Audio In
    Any setting in Vegas I need to change??
    2) In Canopus Let`s edit software I can transfer my Video & Audio through the DV output (at ACEDVio card). But when I use
    Vegas I can only transfer Picture and NO audio available
    Please help me.
    Thank You & Best Regards
    DV
    Rick Mac replied 18 years, 11 months ago 3 Members · 4 Replies
  • Edward Troxel
    October 20, 2007 at 12:51 pm
    When playing back the timeline, the video goes out the firewire and the audio goes out the computer speakers.
    When printing to tape, both video and audio go out firewire.
    If you want both over firewire you’ll have to print-to-tape. You could get sound to your device on normal playback by sending your sound card audio to your other device.
    Edward Troxel
    JETDV Scripts
  • Haizad
    October 20, 2007 at 1:59 pm
    Thanks Jeditdv.
    I will try that
    Do you have any idea what is the best method
    to make the rendering more faster??
    I`m using PC with DDRAM 2G, P4 2.6GHz, 2 SATA H/Disk (400G for Video Captured, 160 G for Project File, 80 G External H/Disk for Back up, 80G for C drive)
    Thank You & Best regards
    Haizad
  • Edward Troxel
    October 20, 2007 at 3:09 pm
    Faster rendering depends on MANY factors and you need to figure out where your particular renders are bogging down. Common things that slow down renders:
    1. Slow CPU/system components
    2. Slow hard drives or rendering from/to the same hard drive
    3. Use of many effects – some are slower than others to process (some are REALLY slow)
    4. Use of 3D track motion
    5. etc…
    Edward Troxel
    JETDV Scripts
  • Rick Mac
    October 20, 2007 at 4:11 pm
    Tweek windows xp for video editing.
    here is the link to a step by step guide.
    https://www.videoguys.com/TweaksWINXPVE.html
    Regards, Rick.
