Activity Forums DVD Authoring Accidently adjusting 16 -235 twice?
  • Accidently adjusting 16 -235 twice?
    Posted by Sharad Patel on November 29, 2006 at 8:50 pm
    If you prepare video footage in a program like After Effects and apply a levels adjustment to go from 0-255 to 16-235, do you have to then compensate when using an mpeg encoder such as Cinema Craft Encoder? Encoders are usually automatically set to 16-235 range when using a preset for NTSC DVD. Would this erroneously further narrow the level range if you had already prepared the master footage within those specs?
    Sharad Patel replied 19 years, 10 months ago 2 Members · 2 Replies
  • Roman Melekh
    November 30, 2006 at 12:56 pm
    if you use CCE or ProCoder you NEED to set 16..235 because any composition/editing software makes it better – no need use CCEs or CPC2 16..235 or ShinkColorSpace…
    If you use mainConcept encoder (Adobe Premiere, etc) – then you not need to set levels because encoder automatically set it.
  • Sharad Patel
    November 30, 2006 at 5:02 pm
    I’m not 100% sure how to interpret the first sentence of your answer. I believe you are advising that it is better to shrink the colorspace and limit the levels in the master footage creation rather then during the encoding. Keep it 1-255 in the encoder if the master footage is already 16-235.
    nostalgia is like heroin
